community:refhepsim
Differences
community:refhepsim [2016/03/23 20:31] – asc | community:refhepsim [2016/04/27 14:04] – asc | ||
Line 1: | Line 1: | ||
- | [[http:// | + | [[http:// |
Line 15: | Line 15: | ||
Here are several links to extending this Wiki for particular detector-performance topics: | Here are several links to extending this Wiki for particular detector-performance topics: | ||
Line 25: | Line 26: | ||
* [[vlhc: | * [[vlhc: | ||
- | Currently these studies are based on [[https:// | + | Currently these studies are based on [[http:// |
+ | Geometry files for full detector simulations can be found in the [[http:// | ||
This manual describes how to work with truth-level samples posted on HepSim. | This manual describes how to work with truth-level samples posted on HepSim. | ||
- | [[https:// | + | [[community: |
+ | We are working on a new, more extensive, manual [[community: | ||
Line 90: | Line 94: | ||
You will see a pop-up GUI browser which displays the MC record. You can search for a given particle name, view data layouts and log files using the [Menu]: | You will see a pop-up GUI browser which displays the MC record. You can search for a given particle name, view data layouts and log files using the [Menu]: | ||
This works for full parton-shower simulations with detailed information on particles. | This works for full parton-shower simulations with detailed information on particles. | ||
Line 231: | Line 237: | ||
If you are interested in a specific reconstruction tag, use " | If you are interested in a specific reconstruction tag, use " | ||
Example: | Example: | ||
hs-find pythia%rfast001 | hs-find pythia%rfast001 | ||
Line 282: | Line 288: | ||
the names are usually have the substring " | the names are usually have the substring " | ||
hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_ | hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_ | ||
Line 307: | Line 313: | ||
fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | ||
hs-ls tev100_ttbar_mg5%rfast001 | hs-ls tev100_ttbar_mg5%rfast001 | ||
hs-get tev100_ttbar_mg5%rfast001 data # download to the " | hs-get tev100_ttbar_mg5%rfast001 data # download to the " | ||
Line 317: | Line 323: | ||
As before, one can also download the files using the URL: | As before, one can also download the files using the URL: | ||
hs-ls http:// | hs-ls http:// | ||
hs-get http:// | hs-get http:// | ||
Line 336: | Line 342: | ||
You can create plots using a number of programming languages, Java, Python, C++, Ruby, Groovy etc. Plots can be done on any platform, without modifying your system. C++ analysis programs require ROOT and Linux. | You can create plots using a number of programming languages, Java, Python, C++, Ruby, Groovy etc. Plots can be done on any platform, without modifying your system. C++ analysis programs require ROOT and Linux. | ||
- | Belows | + | Below we will discuss how to analyse HepSim data using Java, since this approach works on any |
platform (Linux, Mac, Windows) and does not require installation of any platform-specific program. | platform (Linux, Mac, Windows) and does not require installation of any platform-specific program. | ||
As before, make sure that [[http:// | As before, make sure that [[http:// | ||
Line 348: | Line 354: | ||
hs-run ttbar_mg5.py | hs-run ttbar_mg5.py | ||
- | Another approach is to use [[http:// | ||
- | In this example, we will run a Python script that downloads data from URL into the computer memory | ||
+ | Another approach is to use [[http:// | ||
+ | give more flexibility and more libraries for analysis. | ||
+ | In this example, we will run a Python script that downloads data from URL into the computer memory | ||
+ | Here is how to process the analysis using [[http:// | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | fpad ttbar_mg5.py # process it in a batch mode. | ||
+ | Similarly, you can use a more complex [[http:// | ||
wget -O dmelt.zip http:// | wget -O dmelt.zip http:// | ||
Line 387: | Line 409: | ||
+ | Similarly, | ||
===== Method III. Running in a GUI mode ==== | ===== Method III. Running in a GUI mode ==== | ||
Line 396: | Line 419: | ||
Run this code by pressing " | Run this code by pressing " | ||
- | You can also bring up a full-featured GUI editor as this: | + | For Jas4pp, you can start an editor, correct the script, and run it: |
+ | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
+ | Then, use the right mouse button and select "Run Python" | ||
+ | For the DMelt IDE, you can also bring up a full-featured GUI editor as this: | ||
Line 405: | Line 436: | ||
===== Method IV. Running in a GUI mode using URL dialog | ===== Method IV. Running in a GUI mode using URL dialog | ||
If you use DMelt, you can run this code using | If you use DMelt, you can run this code using | ||
Line 478: | Line 511: | ||
The execution of this script will bring-up a window with the lego plot. | The execution of this script will bring-up a window with the lego plot. | ||
You can also look at a simple " | You can also look at a simple " | ||
The code written in Python is attached: | The code written in Python is attached: | ||
====== Reading NLO predictions ====== | ====== Reading NLO predictions ====== | ||
Line 511: | Line 548: | ||
On the left panel, click on the event and then look at "Event info" | On the left panel, click on the event and then look at "Event info" | ||
The scripts that reconstruct cross sections are attached to the HepSim event repository. | The scripts that reconstruct cross sections are attached to the HepSim event repository. | ||
Line 528: | Line 566: | ||
NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | NLO event record includes 4-momenta of particles and event weights (double values). In addition, deviations form central weights are included as an array of integer values as: | ||
You can calculate differential cross sections using online files using this example: | You can calculate differential cross sections using online files using this example: | ||
Line 783: | Line 820: | ||
Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | ||
use these files for the " | use these files for the " | ||
+ | The physics performance studies are [[fcs: | ||
How to convert ProMC to LCIO files is described in | How to convert ProMC to LCIO files is described in | ||
- | You can analyse SLCIO files as described in [[https:// | ||
====== Pileups mixing | ====== Pileups mixing | ||
community/refhepsim.txt · Last modified: 2016/04/28 18:23 by asc
