community:refhepsim [2016/03/31 00:31] asc |
community:refhepsim [2016/03/31 00:41] asc [Method IV. Running in a GUI mode using URL dialog] |
Line 351: | Line 351: | ||
hs-run ttbar_mg5.py | hs-run ttbar_mg5.py | ||
- | Another approach is to use [[http:// | ||
- | In this example, we will run a Python script that downloads data from URL into the computer memory | ||
+ | Another approach is to use [[http:// | ||
+ | give more flexibility and more libraries for analysis. | ||
+ | In this example, we will run a Python script that downloads data from URL into the computer memory | ||
+ | Here is how to process the analysis using [[http:// | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | fpad ttbar_mg5.py # process it in a batch mode. | ||
+ | Similarly, you can use a more complex [[http:// | ||
wget -O dmelt.zip http:// | wget -O dmelt.zip http:// | ||
Line 390: | Line 406: | ||
+ | Similarly, | ||
===== Method III. Running in a GUI mode ==== | ===== Method III. Running in a GUI mode ==== | ||
Line 408: | Line 425: | ||
===== Method IV. Running in a GUI mode using URL dialog | ===== Method IV. Running in a GUI mode using URL dialog | ||
+ | For Jas4pp, you can start an editor, correct the script, and run it: | ||
+ | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
+ | Then, use the right mouse button and select "Run Python" | ||
If you use DMelt, you can run this code using | If you use DMelt, you can run this code using |
