community:refhepsim [2016/03/31 00:38] asc [Method I. Running in a batch mode without downloaded ProMC files] |
community:refhepsim [2016/04/07 14:32] asc |
Line 234: | Line 234: | ||
If you are interested in a specific reconstruction tag, use " | If you are interested in a specific reconstruction tag, use " | ||
Example: | Example: | ||
hs-find pythia%rfast001 | hs-find pythia%rfast001 | ||
Line 285: | Line 285: | ||
the names are usually have the substring " | the names are usually have the substring " | ||
hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_ | hs-get tev13_higgs_pythia8_ptbins data 2 5 pt100_ | ||
Line 310: | Line 310: | ||
fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | fast simulation, version 001). To download the reconstructed events for the reconstruction tag " | ||
hs-ls tev100_ttbar_mg5%rfast001 | hs-ls tev100_ttbar_mg5%rfast001 | ||
hs-get tev100_ttbar_mg5%rfast001 data # download to the " | hs-get tev100_ttbar_mg5%rfast001 data # download to the " | ||
Line 320: | Line 320: | ||
As before, one can also download the files using the URL: | As before, one can also download the files using the URL: | ||
hs-ls http:// | hs-ls http:// | ||
hs-get http:// | hs-get http:// | ||
Line 339: | Line 339: | ||
You can create plots using a number of programming languages, Java, Python, C++, Ruby, Groovy etc. Plots can be done on any platform, without modifying your system. C++ analysis programs require ROOT and Linux. | You can create plots using a number of programming languages, Java, Python, C++, Ruby, Groovy etc. Plots can be done on any platform, without modifying your system. C++ analysis programs require ROOT and Linux. | ||
- | Belows | + | Below we will discuss how to analyse HepSim data using Java, since this approach works on any |
platform (Linux, Mac, Windows) and does not require installation of any platform-specific program. | platform (Linux, Mac, Windows) and does not require installation of any platform-specific program. | ||
As before, make sure that [[http:// | As before, make sure that [[http:// | ||
Line 367: | Line 367: | ||
- | You can also start a GUI, correct the script, and run it: | ||
- | <code bash> | ||
- | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
- | Then, use the right mouse button and select "Run Python" | ||
Similarly, you can use a more complex [[http:// | Similarly, you can use a more complex [[http:// | ||
Line 411: | Line 406: | ||
+ | Similarly, | ||
===== Method III. Running in a GUI mode ==== | ===== Method III. Running in a GUI mode ==== | ||
Line 420: | Line 416: | ||
Run this code by pressing " | Run this code by pressing " | ||
- | You can also bring up a full-featured GUI editor as this: | + | For Jas4pp, you can start an editor, correct the script, and run it: |
+ | <code bash> | ||
+ | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
+ | Then, use the right mouse button and select "Run Python" | ||
+ | For the DMelt IDE, you can also bring up a full-featured GUI editor as this: | ||
Line 429: | Line 433: | ||
===== Method IV. Running in a GUI mode using URL dialog | ===== Method IV. Running in a GUI mode using URL dialog | ||
If you use DMelt, you can run this code using | If you use DMelt, you can run this code using |
