community:refhepsim [2016/03/31 00:39] asc [Method II. Running in a batch mode after downloading ProMC files] |
community:refhepsim [2016/03/31 00:42] asc [Method III. Running in a GUI mode] |
Line 367: | Line 367: | ||
- | You can also start a GUI, correct the script, and run it: | ||
- | <code bash> | ||
- | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
- | Then, use the right mouse button and select "Run Python" | ||
Similarly, you can use a more complex [[http:// | Similarly, you can use a more complex [[http:// | ||
Line 421: | Line 416: | ||
Run this code by pressing " | Run this code by pressing " | ||
- | You can also bring up a full-featured GUI editor as this: | + | For Jas4pp, you can start an editor, correct the script, and run it: |
+ | <code bash> | ||
+ | ./jaspp ttbar_mg5.py # Open the script in the editor | ||
+ | Then, use the right mouse button and select "Run Python" | ||
+ | For the DMelt IDE, you can also bring up a full-featured GUI editor as this: | ||
Line 430: | Line 433: | ||
===== Method IV. Running in a GUI mode using URL dialog | ===== Method IV. Running in a GUI mode using URL dialog | ||
If you use DMelt, you can run this code using | If you use DMelt, you can run this code using |
