community:refhepsim_analysis
Differences
community:refhepsim_analysis [2015/09/15 19:53] – asc | community:refhepsim_analysis [2015/10/23 01:02] – asc | ||
Line 5: | Line 5: | ||
For C++/ROOT, please refer [[asc: | For C++/ROOT, please refer [[asc: | ||
- | To ensure platform independence and a possibility to run programs using web browsers, validation programs are written in Jython, which is an implementation of the Python language on the Java platform. | + | To ensure platform independence and a possibility to run programs using web browsers |
Look at several links: | Look at several links: | ||
- | * [[http:// | + | * [[http:// |
Line 262: | Line 262: | ||
stored inside ProMC data files: | stored inside ProMC data files: | ||
- | | + | ===== Histograms and plots ===== |
- | * [[http:// | + | |
+ | * [[http:// | ||
+ | See also other math and graphics classes in the [[http:// | ||
+ | ===== Lorentz particles and Jets ===== | ||
Java implementation of the longitudinally invariant kT and anti-kT clustering algorithms uses the E-scheme to combine particles (p1+p2) and Eta-Phi space (not Rapidity-Phi). Also, Cambridge/ | Java implementation of the longitudinally invariant kT and anti-kT clustering algorithms uses the E-scheme to combine particles (p1+p2) and Eta-Phi space (not Rapidity-Phi). Also, Cambridge/ | ||
- | See also other classes in [[http:// | + | |
You can build the standard kt-jets using [[http:// | You can build the standard kt-jets using [[http:// | ||
- | [[http:// | + | [[http:// |
+ | ===== Working with ProMC files ===== | ||
+ | Also, look at the ProMC Java API that is used to store data: | ||
Line 287: | Line 301: | ||
information on event weights and uncertainties. | information on event weights and uncertainties. | ||
- | The project uses the core of [[http:// | + | The project uses the community edition |
community/refhepsim_analysis.txt · Last modified: 2016/04/28 15:24 by asc
