Next revision | Previous revision Last revision Both sides next revision | ||
fcs:cepc:2016 [2016/10/31 13:46] asc created |
fcs:cepc:2016 [2016/11/09 15:36] asc |
Line 1: | Line 1: | ||
====== CEPC studies plan ====== | ====== CEPC studies plan ====== | ||
+ | This page describes the CEPC studies following the plan | ||
+ | described in the {{: | ||
+ | This plan was agreed between ANL (Sergei Chekanov) and IHEP (Manqi Ruan). | ||
+ | ====== Monte Carlo simulation samples ====== | ||
+ | The current baseline for the SiCEPC detector is SiCEPCv2 [[http:// | ||
+ | Compared to the previous version (SiCEPCv1) described in [[https:// | ||
+ | The Monte Carlo samples created for this geometry are located under the tag [[http:// | ||
+ | ====== Single electron studies ====== | ||
+ | Setup analysis environment: | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | We will study single-particle files posted to [[http:// | ||
+ | Let's check file availability: | ||
+ | hs-ls pgun_electron_eta3_pt150gev | ||
+ | We will use the reconstruction tag " | ||
+ | Now download the files and calculate track resolution for electrons. We will use this script to make the resolution plot {{: | ||
+ | hs-get pgun_electron_eta3_pt150gev%rfull101 data/ | ||
+ | fpad track_resolution.py | ||
+ | The output resolution is | ||
