fcs:cepc:2016 [2016/11/07 22:25] asc [Single electron studies] |
fcs:cepc:2016 [2016/11/09 15:36] asc |
Line 1: | Line 1: | ||
====== CEPC studies plan ====== | ====== CEPC studies plan ====== | ||
- | This is a plan agreed between ANL (Sergei Chekanov) and IHEP (Manqi Ruan). The document | + | This page describes the CEPC studies following the plan |
+ | described in the {{: | ||
+ | This plan was agreed between ANL (Sergei Chekanov) and IHEP (Manqi Ruan). | ||
+ | ====== Monte Carlo simulation samples ====== | ||
+ | The current baseline for the SiCEPC detector | ||
+ | Compared to the previous version (SiCEPCv1) described in [[https:// | ||
+ | The Monte Carlo samples created for this geometry are located under the tag [[http:// | ||
Line 32: | Line 41: | ||
