fcs:cepc:2016 [2016/11/09 14:28] asc |
fcs:cepc:2016 [2016/11/09 15:36] asc |
Line 1: | Line 1: | ||
====== CEPC studies plan ====== | ====== CEPC studies plan ====== | ||
- | This is a plan agreed between ANL (Sergei Chekanov) and IHEP (Manqi Ruan). The document is {{: | + | This page describes the CEPC studies following the plan |
+ | described in the {{: | ||
+ | This plan was agreed between ANL (Sergei Chekanov) and IHEP (Manqi Ruan). | ||
====== Monte Carlo simulation samples ====== | ====== Monte Carlo simulation samples ====== | ||
- | The current baseline for SiCEPC detector is SiCEPCv2 [[http:// | + | The current baseline for the SiCEPC detector is SiCEPCv2 [[http:// |
- | Compared to the previous version (SiCEPCv1), it has improved PFA, tracking and 3T solenoid. | + | Compared to the previous version (SiCEPCv1) |
The Monte Carlo samples created for this geometry are located under the tag [[http:// | The Monte Carlo samples created for this geometry are located under the tag [[http:// | ||
