User Tools
Site Tools
fcs:cepc:intro
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
fcs:cepc:intro [2016/03/23 01:23]
asc
fcs:cepc:intro [2016/04/08 16:54]
asc [Wired Visualization]
Line 120: Line 120:
 {{:fcs:mc_jets_resol_sidcc1.png|Jet resolution}} {{:fcs:mc_jets_resol_sidcc1.png|Jet resolution}}
 +====== Wired Visualization ======
 +You can run Jas+Wired to visualize the simulated events.  The Wired program is included in the Jas4pp program. Run it as:
 +<code bash>
 +jaspp sifcch1.heprep
 +</code>
 +You can download the heprep file from [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch1/sifcch1.heprep]];
 +Alternatively, visualize the detector as **[File]-[Open data source]-[HepRep]** XML.
 +You will see the detector layout.
 +Now, we will read the event: Open any *.slcio file you copied from HepSim as
 +**[File]-[Open data source]-[LCIO]** file.  Then click a small button [Go] (top menu bar). It will process
 + events.  Then select again **[File]-[New]-[Wired 4 view]**.  You will get an image in the Wired4 display as this:
 +{{:fcs:event.png?400|}}
 +Now press [Go] again to look at next event.
 +If you want to see how data records are organized inside the slcio file,
 +do this **[File]-[New]-[LCSim Event browser]**
 +To view "slcio" files, Jas4pp automatically downloads the detector  geometry from [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/]], therefore, you do not need manual download of heprep files.
  --- //[[[email protected] |Sergei Chekanov]] 2015/10/08 09:31//  --- //[[[email protected] |Sergei Chekanov]] 2015/10/08 09:31//
fcs/cepc/intro.txt ยท Last modified: 2016/04/08 16:54 by asc
