fcs:eic:intro [2016/11/06 16:31] asc [Looking at track resolution] |
fcs:eic:intro [2016/12/09 16:34] asc [Hit timing information] |
Line 110: | Line 110: | ||
Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small). | Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small). | ||
+ | ====== Hit timing information ====== | ||
+ | You can also look at timing of silicon tracker using this script: {{: | ||
+ | <code bash> | ||
+ | hs-get pgun_elec_eta4_pt30gev%rfull052 data # 2 100 get 100 files in 2 threads in the directory " | ||
+ | fpad eic: | ||
+ | The plot is shown here: | ||
====== Looking at track resolution ====== | ====== Looking at track resolution ====== | ||
You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{: | You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{: | ||
- | for the MCparticle container inside LCIO file. We will use the "flat pT" sample called [[http:// | + | for the MCparticle container inside LCIO file. We will use the "flat pT" sample called [[http:// |
Line 157: | Line 171: | ||
- | wget http:// | + | wget http:// |
