User Tools
Site Tools
fcs:eic
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
Next revisionBoth sides next revision
fcs:eic [2016/02/19 16:14] ascfcs:eic [2016/05/25 20:43] asc
Line 1: Line 1:
-====== Electron ion collier studies ======+====== EIC software and detector studies ======
-This wiki explains how to view electron-proton collision events. The analysis package is described in
-[[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=fcs:fpad| FpadSoft]]
-We will use e-p events shown in [[http://atlaswww.hep.anl.gov/hepsim/index.php?c=emp&e=141&t=all]].
-The full simulations are located under the tag "rfull001", which corresponds to SiD simulations.
-====== Visualizing events with Jas ======
-You can run Jas3 to visualize the simulated events.  Install Jas3 as:
-<code bash>
-wget http://java.freehep.org/maven2/org/freehep/jas-assembly/3.1.3/jas-assembly-3.1.3-distribution.tar.gz -O - | tar -xz;
-cd jas-assembly-3.1.3/
-./jas3
-</code>
-For windows:  use the [[http://jas.freehep.org/jas3/Download.html|Jas download page]] and then run it using "jas3.bat".
-Then install the needed plugins **[View]-[Plugin manager]** and install HEP packages "visualization"-
-"Wired4", and "org.lcsim". Restart Jas3.
-Then copy the detector geometry file to the local directory where the file "jas" is:
-<code bash>
-wget http://atlaswww.hep.anl.gov/asc/hepsim/soft/detectors/sidloi3_heprep.tgz -O - | tar -xz;
-</code>
-This will create a directory "detector". This detector corresponds to "rfull001" tag used for the reconstruction of events
-in [[http://atlaswww.hep.anl.gov/hepsim/index.php?c=emp&e=141&t=all]].
-Now we can visualize the detector as **[File]-[Open data source]-[HepRep]** XML and select file "detector/sidloi3/sidloi3.heprep".
-This is how to do this using the command line:
-<code bash>
-./jas3 detector/sidloi3/sidloi3.heprep
-</code>
-Now you should see the detector layout.
-Next, we will read the simulated events: Open any *.slcio file you copied from HepSim using the menu
-**[File]-[Open data source]-[LCIO]**
-For e-p events, use this LCIO file from [[http://atlaswww.hep.anl.gov/hepsim/show.php?item=159&reco=rfull001|rfull001]].
-<code bash>
-wget http://mc.hep.anl.gov/asc/hepsim/events/ep/141gev/lepto6ard_dis5q2//rfull001/lepto6ard_dis5q2_0001_pandora.slcio
-</code>
- Then click a small button [Go] (top menu bar). It will process
- events.  Then select again **[File]-[New]-[Wired 4 view]**. If you want to see how data records are organized inside the slcio file,
-do this **[File]-[New]-[LCSim Event browser]**
-{{:fcs:eic_ep.png}}
-{{:fcs:eic_ep1.png}}
-====== Now to analyse full simulations  ======
-Please read  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=fcs:fpad| FpadSoft]]
- --- //[[[email protected]|Sergei Chekanov]] 2016/01/22 20:36//
 +  * [[fcs:eic:intro| introduction]]
fcs/eic.txt · Last modified: 2016/11/06 19:17 by asc
