fcs:eic
Differences
fcs:eic [2016/02/19 16:19] – [Event display] asc | fcs:eic [2016/03/21 19:49] – asc | ||
Line 1: | Line 1: | ||
====== Electron ion collier studies ====== | ====== Electron ion collier studies ====== | ||
- | This wiki explains how to view electron-proton collision events. | + | This wiki explains how to view electron-proton collision events. |
- | [[https:// | + | |
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
- | We will use e-p events shown in [[http:// | + | The last command optimizes Java packages for the Python language. |
- | The full simulations | + | Now you are ready to run over any file with truth-level and datector-simulation files, such as LCIO and ProMC. This program allows you: |
- | ====== Visualizing events | + | * Downloading and searching HepSim data |
+ | * Processing ProMC files from HepSim | ||
+ | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
+ | * Data analysis (jets, physics vectors, histogram packages) | ||
+ | * Visualisation of reconstructed events using Wired4 display | ||
- | You can run Jas3 to visualize the simulated events. | ||
- | <code bash> | ||
- | wget http:// | ||
- | cd jas-assembly-3.1.3/ | ||
- | ./jas3 | ||
- | For windows: | ||
- | Then install the needed plugins **[View]-[Plugin manager]** and install HEP packages " | ||
- | Then copy the detector geometry file to the local directory where the file "jas" is: | + | We will use e-p events shown in [[http:// |
+ | The full simulation files are located under the tag " | ||
+ | ====== Visualizing events with Wired ====== | ||
+ | Then copy the detector geometry file to the local directory where the file "jas4pp" is: | ||
- | wget http:// | + | wget http:// |
- | This will create | + | This creates |
in [[http:// | in [[http:// | ||
- | Now we can visualize the detector as **[File]-[Open data source]-[HepRep]** XML and select file "detector/sidloi3/ | + | Now we can visualize the detector as **[File]-[Open data source]-[HepRep]** XML and select file " |
This is how to do this using the command line: | This is how to do this using the command line: | ||
- | ./jas3 detector/sidloi3/ | + | jas4pp |
Now you should see the detector layout. | Now you should see the detector layout. |
fcs/eic.txt · Last modified: 2016/11/06 19:17 by asc
