fcs:eic [2016/03/18 20:06] asc |
fcs:eic [2016/11/06 19:17] asc |
Line 1: | Line 1: | ||
- | ====== Electron ion collier studies ====== | + | [[community: |
- | This wiki explains how to view electron-proton collision events. The analysis package is described in | + | ====== EIC software and detector studies ====== |
- | [[https:// | + | |
- | We will use e-p events shown in [[http:// | + | * **[[fcs:eic:intro| Introduction |
- | The full simulations are located under the tag " | + | |
- | ====== Visualizing events with Jas ====== | + | |
- | Install [[https:// | + | |
- | Then copy the detector geometry file to the local directory where the file " | + | |
- | <code bash> | + | |
- | wget http:// | + | |
- | This will create a directory " | + | |
- | in [[http:// | + | |
- | Now we can visualize the detector as **[File]-[Open data source]-[HepRep]** XML and select file | + | |
- | ./fjas sidloi3/ | + | |
- | Now you should see the detector layout. | + | |
- | Next, we will read the simulated events: Open any *.slcio file you copied from HepSim using the menu | + | |
- | **[File]-[Open data source]-[LCIO]** | + | |
- | For e-p events, use this LCIO file from [[http:// | + | |
- | Then click a small button [Go] (top menu bar). It will process | + | |
- | do this **[File]-[New]-[LCSim Event browser]** | + | |
- | ===== Event display ===== | + | |
- | Here are images of ep collision with a scattered electron identified using the PFA. | + | |
- | The images were done using DIS ep samples [[http:// | + | |
- | Reconstructed electron energy from PFA: E=16.92 GeV | + | |
- | “EVGEN” energy: | + | |
- | ====== Now to analyse full simulations | + | |
- | Please read [[https:// | + | |
