fcs:fcchh:intro [2016/04/02 01:04] asc |
fcs:fcchh:intro [2016/04/02 01:12] asc [Visualizing geometry using ROOT] |
Line 8: | Line 8: | ||
This wiki describes physics studies for a FCC-hh detector. | This wiki describes physics studies for a FCC-hh detector. | ||
You can download such samples as discussed in [[http:// | You can download such samples as discussed in [[http:// | ||
+ | This wiki is rather generic, but the detector is still evolving. So, please pay attention to the detector we are using for the ongoing studies. | ||
+ | <note tip> | ||
+ | The current FCC-hh detector is **sifcch4**. It is a compact high-segmented detector based on SiD. You can find this detector | ||
+ | in the [[http:// | ||
+ | Look for **sifcch4.zip** file. This detector corresponds to [[http:// | ||
Line 29: | Line 40: | ||
* Visualisation of reconstructed events using Wired4 display | * Visualisation of reconstructed events using Wired4 display | ||
- | You can find more details in [[http:// | + | You can find more details in [[asc: |
- | All examples for this page are located in the " | + | |
- | <note tip> | ||
- | The current FCC-hh detector is **sifcch4**. It is a compact high-segmented detector based on SiD. You can find this detector | ||
- | in the [[http:// | ||
- | Look for **sifcch4.zip** file. This detector corresponds to [[http:// | ||
Line 109: | Line 110: | ||
The current version of the FCC-hh detector is located in the [[http:// | The current version of the FCC-hh detector is located in the [[http:// | ||
- | zip file with your detector, say " | + | zip file with your detector, say " |
- | You can study this geometry using the description link. | + | You can study this geometry using the "description" |
- | To visualize this detector, use Wired4. Download the detector.zip, | + | To visualize this detector, use Wired4. Download the "detector.zip" file, unpack and locate the file " |
Line 139: | Line 140: | ||
====== Visualizing geometry using ROOT ====== | ====== Visualizing geometry using ROOT ====== | ||
- | (contribution | + | (contribution |
You can also visualize the detector using ROOT. Here are a few steps: | You can also visualize the detector using ROOT. Here are a few steps: |
