fcs:fcchh:sgun [2016/03/22 04:38] asc [SiFCC3 detector] |
fcs:fcchh:sgun [2016/04/19 05:48] asc [SiFCC3 detector] |
Line 1: | Line 1: | ||
+ | [[fcs: | ||
====== Single particle studies ====== | ====== Single particle studies ====== | ||
The results shown on this page use [[https:// | The results shown on this page use [[https:// | ||
+ | <hidden Click here to show how to install it> | ||
Line 8: | Line 12: | ||
+ | ===== Single particles with the SiFCC detector ===== | ||
- | ===== SiFCC3 detector ===== | ||
+ | You can study this the geometry of FCChh-v4 detector using [[http:// | ||
- | You can study this geometry | + | We will download samples in directories **dataNgev** |
+ | <code bash> | ||
+ | hs-get pgun_pi_1to10000gev%rfull006 data1gev 2 100 pi1gev | ||
+ | hs-get pgun_pi_1to10000gev%rfull006 data10gev 2 100 pi10gev | ||
+ | hs-get pgun_pi_1to10000gev%rfull006 data100gev 2 100 pi100gev | ||
+ | hs-get pgun_pi_1to10000gev%rfull006 data1000gev 2 100 pi1000gev | ||
+ | hs-get pgun_pi_1to10000gev%rfull006 data10000gev 2 100 pi10000gev # 10000 GeV sample | ||
+ | </code> | ||
+ | Run a Python script given here: {{: | ||
- | hs-get pgun_pi_1to10000gev%rfull005 rfull005 # download all files | + | fpad pgun1.py data1gev |
+ | fpad pgun1.py data10gev | ||
+ | fpad pgun1.py data100gev | ||
+ | fpad pgun1.py data1000gev | ||
+ | fpad pgun1.py data10000gev | ||
+ | A typical plot for 100 GeV single pion is shown here | ||
+ | <hidden Click to show this image> | ||
