fcs:fcchh:sgun
Differences
fcs:fcchh:sgun [2016/03/22 14:11] – [SiFCC3 detector] asc | fcs:fcchh:sgun [2016/04/02 01:14] – [SiFCC3 detector] asc | ||
Line 1: | Line 1: | ||
+ | [[fcs: | ||
====== Single particle studies ====== | ====== Single particle studies ====== | ||
The results shown on this page use [[https:// | The results shown on this page use [[https:// | ||
+ | <hidden Click here to show how to install it> | ||
Line 8: | Line 12: | ||
===== SiFCC3 detector ===== | ===== SiFCC3 detector ===== | ||
- | You can study this geometry using [[http:// | + | You can study this the |
We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | ||
- | hs-get | + | hs-get pgun_pi_1to10000gev%rfull006 |
- | We will run a Python script given here: {{: | + | Run a Python script given here: {{: |
- | To process these samples, run: | + | |
- | fpad pgun1.py data1gev | + | fpad pgun1.py data1gev |
- | fpad pgun1.py data10gev | + | fpad pgun1.py data10gev |
- | fpad pgun1.py data100gev | + | fpad pgun1.py data100gev |
- | fpad pgun1.py data1000gev | + | fpad pgun1.py data1000gev |
- | fpad pgun1.py data10000gev | + | fpad pgun1.py data10000gev |
- | A typical plot for 100 GeV is shown here | + | A typical plot for 100 GeV single pion is shown here |
- | <hide> | + | <hidden Click to show this image> |
- | </hide> | + | </hidden> |
fcs/fcchh/sgun.txt · Last modified: 2016/09/25 00:29 by asc
