Next revision | Previous revision Next revision Both sides next revision | ||
fcs:fcchh:zprime [2016/03/22 04:28] asc created |
fcs:fcchh:zprime [2016/03/23 13:47] asc |
Line 1: | Line 1: | ||
+ | [[fcs: | ||
====== Boosted particle studies ====== | ====== Boosted particle studies ====== | ||
+ | The results shown on this page use [[https:// | ||
+ | <hidden Click here to show how to install it> | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | ===== SiFCC3 detector ===== | ||
+ | You can study this the geometry of the FCChh-v3 detector using [[http:// | ||
+ | Download Z'(10 TeV) to XX final state as: | ||
+ | hs-get tev10mumu_pythia6_zprime10tev_qqbar%rfull005 | ||
+ | hs-get tev10mumu_pythia6_zprime10tev_ttbar%rfull005 | ||
+ | hs-get tev10mumu_pythia6_zprime10tev_ww%rfull005 | ||
+ | An example code which creates jet masses of anti-kT jets (R=0.8) is {{: | ||
+ | It fills 3 histograms with jet masses for leading in pT antiKT jets for Z(10 TeV) to W+W- sample | ||
+ | Run it as: | ||
+ | fpad jetmass.py tev10mumu_pythia6_zprime10tev_ww%rfull005 | ||
+ | The created image is shown below | ||
+ | You can write a C++ code which calls the FastJet (with jet substructure variables) using the packages posted to [[fcs: |
