fcs:sid:intro [2016/03/22 00:06] asc |
fcs:sid:intro [2016/03/23 01:39] asc |
Line 1: | Line 1: | ||
+ | [[fcs: | ||
====== SiD detector studies ====== | ====== SiD detector studies ====== | ||
- | **People:** S.Chekanov, M.Demarteau | ||
- | This wiki describes physics studies using the SiD detector. | ||
- | It is designed to work " | ||
- | detector simulations. The Monte Carlo files for this package are posted to [[http:// | ||
+ | This wiki describes physics studies using the SiD detector. The following HepSim samples are available: | ||
- | You can find Monte Carlo samples in the LCIO format using the [[http:// | + | * gev250ee_pythia6_qcd_all |
+ | * gev250ee_pythia6_zpole_ee | ||
+ | * gev250ee_pythia6_zpole_tautau (Z → tautau) | ||
+ | * gev250ee_pythia6_zpole_mumu | ||
+ | * gev250ee_pythia6_zpole_bbar | ||
+ | * gev250ee_pythia6_higgs_zz_4l | ||
+ | * gev250ee_pythia6_higgs_bbar | ||
+ | * gev250ee_pythia6_higgs_gamgam | ||
+ | You can find the Monte Carlo samples in the LCIO format using the [[http:// | ||
This link prints all event samples after full detector simulations ("tag rfull001" | This link prints all event samples after full detector simulations ("tag rfull001" | ||
Select " | Select " | ||
Line 13: | Line 21: | ||
- | The results shown on this page have been updated using [[https:// | + | The results shown on this page use the [[https:// |
The installation does not have external dependencies besides Java. Make sure Java7 and above is installed. | The installation does not have external dependencies besides Java. Make sure Java7 and above is installed. | ||
Then run these commands to install the package using Linux/Mac with the " | Then run these commands to install the package using Linux/Mac with the " | ||
Line 34: | Line 42: | ||
You can find more details in [[http:// | You can find more details in [[http:// | ||
All examples for this page are located in the " | All examples for this page are located in the " | ||
====== Examples ====== | ====== Examples ====== | ||
Line 225: | Line 234: | ||
[[http:// | [[http:// | ||
- | Look the Java API definition of the needed objects in [[http:// | + | Look the Java API definition of the needed objects in [[http:// |
BeamCalHits | BeamCalHits | ||
Line 263: | Line 273: | ||
VXD_TrackerHits | VXD_TrackerHits | ||
====== Detector geometry ====== | ====== Detector geometry ====== | ||
The Monte Carlo files located in [[http:// | The Monte Carlo files located in [[http:// | ||
Line 348: | Line 358: | ||
If you want to see how data records are organized inside the slcio file, | If you want to see how data records are organized inside the slcio file, | ||
do this **[File]-[New]-[LCSim Event browser]** | do this **[File]-[New]-[LCSim Event browser]** | ||
- | ====== People ====== | ||
- | This collection of tools for future collider studies | ||
- | in collaboration with Jan Strube (PNNL) ([email protected]) and Ashutosh Kotwal (Duke U) [email protected]. | ||
- | The Java part of the simulator for the linear collider was designed N. Graf, J. McCormick, T.Jonson | ||
