hpc:alpgenbuildingnotes
Differences
hpc:alpgenbuildingnotes [2014/01/09 15:58] – jchilders | hpc:alpgenbuildingnotes [2014/01/09 16:04] – jchilders | ||
Line 6: | Line 6: | ||
=== For BG/P & BG/Q === | === For BG/P & BG/Q === | ||
- | For now, use the IBM compiler. That requires | + | For now, use the IBM compiler. That requires '' |
to have the following changes | to have the following changes | ||
<code fortran> | <code fortran> | ||
Line 18: | Line 18: | ||
endif | endif | ||
- | After a | + | Doing a '' |
- | or | + | |
- | fails, one needs to do the following: | + | |
mpixlf77 | mpixlf77 | ||
Line 29: | Line 25: | ||
(or similar) to pass the linking phase. | (or similar) to pass the linking phase. | ||
===For BG/Q=== | ===For BG/Q=== | ||
- | Run on the command line: | + | On the command line, run |
- | and change | + | and change |
- | to | + | |
ifeq ($(shell uname), | ifeq ($(shell uname), | ||
Line 48: | Line 41: | ||
endif | endif | ||
- | On line 182 of the file '' | + | |
- | '' | + | On line 182 of the file '' |
+ | to | ||
There' | There' |
hpc/alpgenbuildingnotes.txt · Last modified: 2014/03/24 13:08 by jchilders
