hpc:alpgenbuildingnotes [2014/01/09 16:38] jchilders old revision restored (2014/01/09 10:01) |
hpc:alpgenbuildingnotes [2014/03/24 13:08] jchilders |
Line 3: | Line 3: | ||
==== Machine dependent compile time changes ==== | ==== Machine dependent compile time changes ==== | ||
- | === For BG/P === | ||
- | For now, use the IBM compiler. That requires '' | ||
- | to have the following changes | ||
- | <code fortran> | ||
- | ifeq ($(shell uname), | ||
- | # FFF = gfortran -fno-automatic | ||
- | # FF90 = gfortran -fno-automatic | ||
- | FFF = mpixlf77 | ||
- | FF90 = mpixlf77 | ||
- | #FFF = g77 -O1 -Wall -fno-automatic -Wno-globals -fno-backslash \ | ||
- | # -ffast-math | ||
- | endif | ||
- | Doing a '' | ||
- | <code bash> | ||
- | mpixlf77 | ||
- | (or similar) to pass the linking phase. | ||
===For BG/Q=== | ===For BG/Q=== | ||
Line 36: | Line 15: | ||
FFF = mpif77 -fno-automatic | FFF = mpif77 -fno-automatic | ||
FF90 = mpif90 -fno-automatic | FF90 = mpif90 -fno-automatic | ||
+ | # Or if you want optimization use this | ||
+ | # FFF = mpixlf77 -O5 -qarch=qp -qtune=qp -qsave -qsimd=auto -qhot=level=1 -qprefetch -qunroll=yes -qnoipa -qfloat=rsqrt: | ||
+ | # FF90 = mpixlf90 -O5 -qarch=qp -qtune=qp -qsave -qsimd=auto -qhot=level=1 -qprefetch -qunroll=yes -qnoipa -qfloat=rsqrt: | ||
#FFF = g77 -O1 -Wall -fno-automatic -Wno-globals -fno-backslash \ | #FFF = g77 -O1 -Wall -fno-automatic -Wno-globals -fno-backslash \ | ||
# -ffast-math | # -ffast-math | ||
Line 73: | Line 55: | ||
- | + | Run \\ | |
- | module swap PrgEnv-pgi PrgEnv-gnu \\ | + | '' |
That requires '' | That requires '' | ||
<code make> | <code make> | ||
Line 89: | Line 71: | ||
=== Edison === | === Edison === | ||
- | + | Run \\ | |
- | module swap PrgEnv-intel PrgEnv-gnu \\ | + | '' |
Line 110: | Line 92: | ||
In subroutine '' | In subroutine '' | ||
- | add these lines | + | add/ |
<code fortran> | <code fortran> | ||
integer mpirank | integer mpirank | ||
character*5 rankstring | character*5 rankstring | ||
common/ | common/ | ||
+ | c local variables | ||
+ | double precision dummy, | ||
+ | integer i, | ||
+ | c | ||
Near line 230, just before \\ | Near line 230, just before \\ | ||
- | sdd the lines | + | add the lines |
C MPI variables | C MPI variables | ||
Line 135: | Line 122: | ||
call MPI_FINALIZE(ierror) | call MPI_FINALIZE(ierror) | ||
write(6,*) 'MPI finalized: rank ', mpirank | write(6,*) 'MPI finalized: rank ', mpirank | ||
- | write( rankstring, '(i5.5)' ) mpirank | + | write( rankstring, '(i8.8)' ) mpirank |
- | c | + | c work in a unique directory |
if(retval.ne.0) then | if(retval.ne.0) then | ||
- | endif | + | |
- | call chdir(rankstring, | + | |
- | if(retval.ne.0) then | + | |
endif | endif | ||
c end of MPI block | c end of MPI block | ||
Line 164: | Line 147: | ||
- | include ' | + | |
(near line 4584) add the lines: | (near line 4584) add the lines: | ||
Line 175: | Line 158: | ||
Near line 4588, replace | Near line 4588, replace | ||
- | call alustc(fname,' | + | |
with | with | ||
- | call alustc(' | + | |
immediately after | immediately after | ||
<code fortan> | <code fortan> | ||
- | write(6,*) 'Run parameters and diagnostics written to ' | + | |
Line 204: | Line 187: | ||
This ensures everywhere is reading from the input file instead of '' | This ensures everywhere is reading from the input file instead of '' | ||
