hpc:argobalsam [2015/07/01 15:09] jchilders [Installation] |
hpc:argobalsam [2016/01/26 17:56] jchilders [Installation] |
Line 89: | Line 89: | ||
- Activate virtual environment: | - Activate virtual environment: | ||
- On Edison: | - On Edison: | ||
- | - To use '' | + | - To use '' |
- Install needed software: | - Install needed software: | ||
+ | - if you have less than python-2.7 you need '' | ||
Line 117: | Line 118: | ||
+ | - If you are using MySQL: <code python> | ||
+ | DATABASES = { | ||
- Sync your database: | - Sync your database: | ||
- | - For Older Django using South: | + | - For Older Django using South (pre-1.7): |
- <code bash> python manage.py syncdb </ | - <code bash> python manage.py syncdb </ | ||
- Create the first migration <code bash> python manage.py schemamigration balsam_core --initial </ | - Create the first migration <code bash> python manage.py schemamigration balsam_core --initial </ | ||
Line 125: | Line 139: | ||
- Create the first migration <code bash> python manage.py schemamigration argo_core --initial </ | - Create the first migration <code bash> python manage.py schemamigration argo_core --initial </ | ||
- Apply the first migration <code bash> python manage.py migrate argo_core --fake </ | - Apply the first migration <code bash> python manage.py migrate argo_core --fake </ | ||
- | - For newer Django: | + | - For newer Django |
===== Git Tag Notes ===== | ===== Git Tag Notes ===== |
