User Tools
Site Tools
hpc:argobalsam
Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
hpc:argobalsam [2015/07/23 15:04]
jchilders [Installation]
hpc:argobalsam [2016/01/26 17:56]
Line 89: Line 89:
   - Activate virtual environment: ''. argobalsam_env/bin/activate''   - Activate virtual environment: ''. argobalsam_env/bin/activate''
     - On Edison:     - On Edison:
-      - To use ''pip'' you need a certificate so run ''mk_pip_cabundle.sh'', then include '--cert ~/.pip/cabundle' in all your pip commands.+      - To use ''pip'' you need a certificate so run ''mk_pip_cabundle.sh'', then include ''%%--%%cert ~/.pip/cabundle'' in all your pip commands.
   - Install needed software:   - Install needed software:
     - ''pip install django''     - ''pip install django''
-      - if you have less than python-2.7 you need ''pip install django=1.6.2''+      - if you have less than python-2.7 you need ''pip install django==1.6.2''
     - ''pip install south''     - ''pip install south''
     - ''pip install pika''     - ''pip install pika''
Line 118: Line 118:
     'argo_core',     'argo_core',
 +</code>
 +    - If you are using MySQL: <code python>
 +DATABASES = {
 +    'default': {
 +        'ENGINE': 'django.db.backends.mysql',
 +        'NAME': 'your_table_name_goes_here',
 +        'USER': 'your_login',
 +        'PASSWORD': 'your_password',
 +        'HOST': '127.0.0.1',
 +        'PORT': '',
 +        'CONN_MAX_AGE': 2000000,
 </code> </code>
   - Sync your database:    - Sync your database:
hpc/argobalsam.txt ยท Last modified: 2016/02/24 21:31 by jchilders
