Next revision | Previous revision | ||
hpc:athenanotes [2015/01/28 14:08] jchilders created |
hpc:athenanotes [2015/03/06 14:53] jchilders [Running Generate_trf to get Alpgen Input Card Only] |
Line 1: | Line 1: | ||
- | ====== Athena Notes | + | ====== Athena Notes ====== |
- | ====== Simulation, Digitization, | + | ====== Simulation, Digitization, |
- | ===== In Athena Release 17.7.3.6 | + | ===== In Athena Release 17.7.3.6 |
- | - <code bash> AtlasG4_trf.py inputEvgenFile=< | + | - Run ATLAS Geant4 Simulation: |
+ | - Run Detector digitization: | ||
+ | - Run Physics Object Reconstruction: | ||
+ | ===== Running Generate_trf to get Alpgen Input Card Only ===== | ||
+ | Need a release with at least AlpGenControl-00-00-27 or check it out locally. | ||
+ | Just run your Generate_trf command with <code bash> |
