hpc:athenanotes [2015/01/28 14:10] jchilders |
hpc:athenanotes [2015/03/06 14:27] jchilders [Running Generate_trf to get Alpgen Input Card Only] |
Line 6: | Line 6: | ||
===== In Athena Release 17.7.3.6 ===== | ===== In Athena Release 17.7.3.6 ===== | ||
- | - Run ATLAS Geant4 Simulation: <code bash> AtlasG4_trf.py inputEvgenFile=< | + | - Run ATLAS Geant4 Simulation: <code bash> AtlasG4_trf.py inputEvgenFile=< |
- | - Run Detector digitization: | + | - Run Detector digitization: |
- | - Run Physics Object Reconstruction: | + | - Run Physics Object Reconstruction: |
+ | ===== Running Generate_trf to get Alpgen Input Card Only ===== | ||
+ | Need a release with at least AlpGenControl-00-00-27 or check it out locally. | ||
+ | Just run your Generate_trf command with '' |
