hpc:athenanotes [2015/01/29 14:08] jchilders [In Athena Release 17.7.3.6] |
hpc:athenanotes [2015/03/06 14:53] jchilders [Running Generate_trf to get Alpgen Input Card Only] |
Line 8: | Line 8: | ||
- Run ATLAS Geant4 Simulation: <code bash> AtlasG4_trf.py inputEvgenFile=< | - Run ATLAS Geant4 Simulation: <code bash> AtlasG4_trf.py inputEvgenFile=< | ||
- Run Detector digitization: | - Run Detector digitization: | ||
- | - Run Physics Object Reconstruction: | + | - Run Physics Object Reconstruction: |
+ | ===== Running Generate_trf to get Alpgen Input Card Only ===== | ||
+ | Need a release with at least AlpGenControl-00-00-27 or check it out locally. | ||
+ | Just run your Generate_trf command with <code bash> |
