hpc:athenanotes [2015/03/06 14:22] jchilders |
hpc:athenanotes [2015/03/06 14:53] jchilders [Running Generate_trf to get Alpgen Input Card Only] |
Line 12: | Line 12: | ||
===== Running Generate_trf to get Alpgen Input Card Only ===== | ===== Running Generate_trf to get Alpgen Input Card Only ===== | ||
- | Just run your Generate_trf command with '' | + | |
+ | Need a release with at least AlpGenControl-00-00-27 or check it out locally. | ||
+ | Just run your Generate_trf command with <code bash>--athenaopts=" |
