hpc:bghep:benchmarks [2014/02/04 18:42] asc |
hpc:bghep:benchmarks [2014/05/27 16:45] edmay |
Line 3: | Line 3: | ||
====== IO benchmarks using ProMC format ====== | ====== IO benchmarks using ProMC format ====== | ||
+ | (E.May) | ||
A number of IO tests are being performed on BlueGene/Q | A number of IO tests are being performed on BlueGene/Q | ||
Line 10: | Line 10: | ||
A test to see if I can edit this page! - edmay | A test to see if I can edit this page! - edmay | ||
A [[http:// | A [[http:// | ||
- | To be migrated here! | + | |
+ | Some comments on data/plots of running Pythia6 with ProMC & ProBuf on BG/Q Vesta. | ||
+ | This uses the Fortran code from the latest 1.1 tar file which simulates 5000 event | ||
+ | per core for pp at 4on4 TeV. Except for the normalizing point at 1 core, all runs | ||
+ | use 16 cores per node. Jobs were run through 4096 cores. This last point produced | ||
+ | 20.5 M ev in 1197 sec (20 mins). | ||
+ | ===== Fig 1 ===== | ||
+ | The first plot shows the (inverse) rate as a function | ||
+ | of core. There is a noticiable jog at 1024 cores and above. I ran a second job at | ||
+ | 1024 which reproducible result. I have no reasonable explanation for the observed | ||
+ | behavior. I remark that some earlier studies at smaller number of cores showed this | ||
+ | kind of behavior when mixing the number of nodes/cores down without event level i/o | ||
+ | see http:// | ||
+ | ===== Fig 2 ===== | ||
+ | Plot 2 shows the data arranged as a speed-up presentation. Note the use of log scales which minimises the nonlinearity. | ||
+ | ===== Fig 3 ===== | ||
+ | A more appropriate measure is shown in Plot 3 which is the effective utilization of | ||
+ | the multiple cores. Above 100 cores the fraction begins to drop reaching only 20% for 1024 (and above) cores. This is really rather poor performance! The plot 5 shows the I/O performance which shows that the code is not really pushing the I/O capabilities of Vesta. | ||
+ | This plot shows the efficiency (R_1c / Nc / R_Nc) v. Nc, where | ||
+ | R == sec/ | ||
+ | Nc == number of cores used in job | ||
+ | For a perfect speed-up this would always | ||
+ | smaller size is that 80% is usually achievable while 20% is quite low and the | ||
+ | usual interpretation is the code has high fraction of serialization. For this | ||
+ | case it would be more efficient to run 8 jobs of 512 cores than 1 job of 4096. | ||
+ | This of course is speculation on my part as I have not identified to cause of | ||
+ | the inefficiency! | ||
+ | ===== Fig 4 ===== | ||
+ | The ALCF experts suggested the I/O model of 1 directory and many files in that 1 directory would preform badly due to lock contention | ||
+ | on the directory! Thus the example code was modified to use a model | ||
+ | of 1 output promc data file per directory. Running the modified code | ||
+ | produced the following figures: | ||
+ | http:// | ||
+ | Focusing on the ' | ||
+ | improvements both at low core numbers and a high core numbers: 80% rising to 90% and 20% rising to 40% respectively. | ||
+ | The large step between 512 to 1024 is still present! | ||
+ | As part of the bootcamp for MIRA the code was moved to the | ||
+ | BG/Q Mira and a subset up the benchmarks were run in the new | ||
+ | IO model. The results are shown in | ||
+ | http:// | ||
+ | Again focusing on the Efficiency plot the results are very | ||
+ | similar. This suggest when using this naive IO model of each | ||
+ | mpi rank writing its own output ProMC file should be limited to | ||
+ | jobs of 512 cores or less for good utilization of the machine | ||
+ | and IO resouces. This is OK for Vesta where the minimum charging | ||
+ | is 32 nodes (ie 512 cores). While on Mira the minimum is 512 | ||
+ | nodes (ie 8192 cores) there is not a good match! | ||
[[hpc: | [[hpc: | ||
