hpc:bghep:benchmarks [2014/02/17 19:31] asc [Fig 3] |
hpc:bghep:benchmarks [2014/05/27 16:45] edmay |
Line 48: | Line 48: | ||
R == sec/ | R == sec/ | ||
Nc == number of cores used in job | Nc == number of cores used in job | ||
- | < | + | </code> |
For a perfect speed-up this would always be 1. My experience with clusters of | For a perfect speed-up this would always be 1. My experience with clusters of | ||
Line 61: | Line 61: | ||
+ | The ALCF experts suggested the I/O model of 1 directory and many files in that 1 directory would preform badly due to lock contention | ||
+ | on the directory! Thus the example code was modified to use a model | ||
+ | of 1 output promc data file per directory. Running the modified code | ||
+ | produced the following figures: | ||
+ | http:// | ||
+ | Focusing on the ' | ||
+ | improvements both at low core numbers and a high core numbers: 80% rising to 90% and 20% rising to 40% respectively. | ||
+ | The large step between 512 to 1024 is still present! | ||
+ | As part of the bootcamp for MIRA the code was moved to the | ||
+ | BG/Q Mira and a subset up the benchmarks were run in the new | ||
+ | IO model. The results are shown in | ||
+ | http:// | ||
+ | Again focusing on the Efficiency plot the results are very | ||
+ | similar. This suggest when using this naive IO model of each | ||
+ | mpi rank writing its own output ProMC file should be limited to | ||
+ | jobs of 512 cores or less for good utilization of the machine | ||
+ | and IO resouces. This is OK for Vesta where the minimum charging | ||
+ | is 32 nodes (ie 512 cores). While on Mira the minimum is 512 | ||
+ | nodes (ie 8192 cores) there is not a good match! | ||
[[hpc: | [[hpc: | ||
