User Tools
Site Tools
hpc:bghep:manual
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hpc:bghep:manual [2014/02/04 18:42]
asc
hpc:bghep:manual [2014/05/15 19:52]
asc [BG@HEPlib manual]
Line 1: Line 1:
-====== BG-HEP manual ======+====== BG@HEPlib manual ======
 (S.Chekanov, E.May) (S.Chekanov, E.May)
-{{:hpc:bghep:bghep1.png?800x20|BG-HEP library}}+{{:hpc:bghep:bghep1.png?1600x20|BG@HEPlib library}}
 ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of [[https://www.alcf.anl.gov/ | Argonne Leadership Computing Facility]].   ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/Mira) of [[https://www.alcf.anl.gov/ | Argonne Leadership Computing Facility]].
-The main features of the BG-HEP library are:+The main features of the BG@HEP library are:
   * Many packages have been redesigned removing ROOT, HBOOK  and CERNLIB calls   * Many packages have been redesigned removing ROOT, HBOOK  and CERNLIB calls
Line 15: Line 15:
-  * CERNLIBlite  - a light version of [[http://www.desy.de/~chekanov/cernlib/ | CERNLIB]] (without HBOOK) +  * CERNLIBlite  - a light version of [[http://www.desy.de/~chekanov/cernlib/ | CERNLIB]] (without HBOOK, my slimmed version SC
-  * fastjet +  * fastjet (v 3.03) -  jet library [[http://fastjet.fr/ | Fastjet]]
-  * hepmc +  * hepmc  (v 2.06.09) - [[http://lcgapp.cern.ch/project/simu/HepMC/ | HEPMC library]]
-  * lhapdf5 +  * lhapdf5 (v5.9) - [[https://lhapdf.hepforge.org/ | LHAPDF the Les Houches Accord PDF Interface]]
-  * lhapdf6 +  * lhapdf6 (v6.4)
-  * mcfm MCFM NLO program with ProMC output ntuples +  * [[http://mcfm.fnal.gov/ | MCFM v.6.7]] - NLO program with ProMC output for ntuples
-  * jetphox  - A JetPhox NLO program +  * jetphox (v3.02) - A JetPhox NLO program
-  * promc  +  * promc   (v1.3) - [[https://atlaswww.hep.anl.gov/asc/promc/ | ProMC data I/O library]]
-  * protobuf +  * protobuf (v2.5) - (comes with ProMC)
-  * pythia8 - Pythia8 with ProMC output ntuples +  * pythia8 (v8180)- Pythia8 with [[https://atlaswww.hep.anl.gov/asc/promc/ProMC]] output
-  * zlib+  * [[http://lapth.cnrs.fr/PHOX_FAMILY/jetphox.html | jetphox]] 1.302  - NLO program with [[https://atlaswww.hep.anl.gov/asc/promc/ | ProMC]] output
 +  * zlib (v2.09)
 To setup the library, run this setup script: To setup the library, run this setup script:
Line 33: Line 34:
 </code> </code>
-This will setup the above libraries. Each library has a "Makefile" which can compile and run a program on BlueGene/Q+This will setup the above libraries. Each library has a "Makefile" which can be compiled and run a program on BlueGene/Q
 +Look at this "bghep_setup.sh" to see location of each library.
 +A list of Monte Carlo simulations and NLO programs generated on BlueGene/Q (Vesta, ANL) is listed on the **[[http://atlaswww.hep.anl.gov/hepsim/ | =HepSim= event repository]]**.
 +====== Acknowledgment ======
 +//This research used resources of the Argonne Leadership Computing Facility at Argonne National Laboratory, which is supported by the Office of Science of the U.S. Department of Energy under contract DE-AC02-06CH11357.
 [[hpc:bghep:| << back]] [[hpc:bghep:| << back]]
  --- //[[[email protected]|Sergei Chekanov]] 2014/02/04 10:24//  --- //[[[email protected]|Sergei Chekanov]] 2014/02/04 10:24//
hpc/bghep/manual.txt · Last modified: 2015/10/08 19:30 by asc
