hpc:bghep:manual [2014/02/04 18:42] asc |
hpc:bghep:manual [2014/05/15 19:52] asc [BG@HEPlib manual] |
Line 1: | Line 1: | ||
- | ====== BG-HEP manual ====== | + | ====== BG@HEPlib |
(S.Chekanov, | (S.Chekanov, | ||
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/ | ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/ | ||
- | The main features of the BG-HEP library are: | + | The main features of the BG@HEP library are: |
* Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls | * Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls | ||
Line 15: | Line 15: | ||
- | * CERNLIBlite | + | * CERNLIBlite |
- | * fastjet | + | * fastjet |
- | * hepmc | + | * hepmc (v 2.06.09) - [[http:// |
- | * lhapdf5 | + | * lhapdf5 |
- | * lhapdf6 | + | * lhapdf6 |
- | * mcfm - MCFM NLO program with ProMC output ntuples | + | * [[http://mcfm.fnal.gov/ | MCFM v.6.7]] - NLO program with ProMC output |
- | * jetphox | + | * jetphox |
- | * promc | + | * promc (v1.3) - [[https:// |
- | * protobuf | + | * protobuf |
- | * pythia8 - Pythia8 with ProMC output | + | * pythia8 |
- | * zlib | + | * [[http:// |
+ | * zlib (v2.09) | ||
To setup the library, run this setup script: | To setup the library, run this setup script: | ||
Line 33: | Line 34: | ||
- | This will setup the above libraries. Each library has a " | + | This will setup the above libraries. Each library has a " |
+ | Look at this " | ||
+ | A list of Monte Carlo simulations and NLO programs generated on BlueGene/Q (Vesta, ANL) is listed on the **[[http:// | ||
+ | ====== Acknowledgment ====== | ||
+ | //This research used resources of the Argonne Leadership Computing Facility at Argonne National Laboratory, which is supported by the Office of Science of the U.S. Department of Energy under contract DE-AC02-06CH11357. | ||
[[hpc: | [[hpc: | ||
