hpc:bghep:manual [2014/02/10 19:35] asc |
hpc:bghep:manual [2014/05/15 19:52] asc [BG@HEPlib manual] |
Line 1: | Line 1: | ||
- | ====== BG-HEPlib manual ====== | + | ====== BG@HEPlib manual ====== |
(S.Chekanov, | (S.Chekanov, | ||
ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/ | ANL BG-HEP library is designed to run CPU-intensive HEP calculations on the BlueGene/Q supercomputer (Vesta/ | ||
- | The main features of the BG-HEP library are: | + | The main features of the BG@HEP library are: |
* Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls | * Many packages have been redesigned removing ROOT, HBOOK and CERNLIB calls | ||
Line 15: | Line 15: | ||
- | * CERNLIBlite | + | * CERNLIBlite |
- | * fastjet (v 3.03) | + | * fastjet (v 3.03) - jet library [[http:// |
- | * hepmc (v 2.06.09) | + | * hepmc (v 2.06.09) |
- | * lhapdf5 (v5.9) | + | * lhapdf5 (v5.9) |
* lhapdf6 (v6.4) | * lhapdf6 (v6.4) | ||
- | * mcfm - (v6.7) MCFM NLO program with ProMC output ntuples | + | * [[http://mcfm.fnal.gov/ | MCFM v.6.7]] - NLO program with ProMC output |
* jetphox (v3.02) - A JetPhox NLO program | * jetphox (v3.02) - A JetPhox NLO program | ||
- | * promc | + | * promc |
- | * protobuf (v2.5) | + | * protobuf (v2.5) - (comes with ProMC) |
- | * pythia8 (v8180)- Pythia8 with ProMC output | + | * pythia8 (v8180)- Pythia8 with [[https:// |
- | * [[http:// | + | * [[http:// |
* zlib (v2.09) | * zlib (v2.09) | ||
Line 37: | Line 37: | ||
Look at this " | Look at this " | ||
+ | A list of Monte Carlo simulations and NLO programs generated on BlueGene/Q (Vesta, ANL) is listed on the **[[http:// | ||
+ | ====== Acknowledgment ====== | ||
+ | //This research used resources of the Argonne Leadership Computing Facility at Argonne National Laboratory, which is supported by the Office of Science of the U.S. Department of Energy under contract DE-AC02-06CH11357. | ||
