hpc:lcgcmake
Differences
hpc:lcgcmake [2015/08/21 01:26] – [Installing on Cooley@ALCF] jchilders | hpc:lcgcmake [2015/08/24 15:26] – [LCGCMake] jchilders | ||
Line 6: | Line 6: | ||
The basic installation instructions are here for a standard Scientific Linix CERN 6 installation: | The basic installation instructions are here for a standard Scientific Linix CERN 6 installation: | ||
- | ==== Installing on Cooley@ALCF ==== | + | ===== Installing on Cooley@ALCF |
- | | + | ==== Setup ==== |
Line 14: | Line 16: | ||
- | - Install Dependencies | + | === Install Dependencies |
- | | + | === procmail |
- | * edit '' | + | * '' |
- | | + | * press enter when prompted |
- | * press enter when prompted | + | * this only compiles '' |
- | * this only compiles '' | + | * '' |
- | * '' | + | === libxml2 === |
- | | + | * [[http:// |
- | | + | === libxslt === |
- | * '' | + | * [[http:// |
- | | + | * you may need to manually copy ./ |
- | * '' | + | === export environment |
- | * '' | + | ==== LCGCMake ==== |
- | * '' | + | === Get LCGCMake repository |
- | * Edit '' | + | * '' |
+ | === Before you build === | ||
+ | * You have to force cmake to identify your machine as slc6 because some of the tarballs live on a webserver with '' | ||
+ | if(os_release MATCHES " | ||
+ | set(os " | ||
+ | string(REGEX REPLACE " | ||
+ | else() | ||
+ | message(WARNING " | ||
+ | set(os linux) | ||
+ | set(osvers) | ||
+ | endif() | ||
+ | endif()</ | ||
+ | execute_process(COMMAND cat / | ||
+ | set(os " | ||
+ | else() | ||
+ | set(os " | ||
+ | set(osvers " | ||
+ | endif() | ||
+ | endif()</ | ||
+ | * Edit '' | ||
LCGPackage_Add( | LCGPackage_Add( | ||
Line 84: | Line 112: | ||
DEPENDS Boost | DEPENDS Boost | ||
- | | + | * Edit '' |
- | * After '' | + | -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ |
- | - Create setup environment <file bash setup.sh> | + | * Edit '' |
+ | -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | ||
+ | * Edit '' | ||
+ | -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} | ||
+ | * Edit '' | ||
+ | * Edit '' | ||
+ | set(hepmc3_source_command GIT_REPOSITORY http:// | ||
+ | === Building LCG === | ||
+ | === When Build Fails === | ||
+ | When a build fails, look at this list for fixes, fix, then continue with '' | ||
+ | * Create setup environment <file bash setup.sh> | ||
soft add +cmake | soft add +cmake | ||
soft add +gcc-4.8.1 | soft add +gcc-4.8.1 |
hpc/lcgcmake.txt · Last modified: 2015/08/24 19:29 by jchilders
