hpc:lcgcmake [2015/08/23 23:15] jchilders [LCGCMake] |
hpc:lcgcmake [2015/08/24 15:26] jchilders [LCGCMake] |
Line 120: | Line 120: | ||
-DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | ||
* Edit '' | * Edit '' | ||
+ | * Edit '' | ||
+ | set(hepmc3_source_command GIT_REPOSITORY http:// | ||
=== Building LCG === | === Building LCG === | ||
Line 129: | Line 132: | ||
* After the '' | * After the '' | ||
- | * After '' | + | * After '' |
* After ROOT 6 downloads and fails the build, you can make the following edits to fix the ODBC files. Add to the files '' | * After ROOT 6 downloads and fails the build, you can make the following edits to fix the ODBC files. Add to the files '' | ||
