User Tools
Site Tools
hpc:lcgcmake
Differences
Link to this comparison view
Next revision
Previous revision
hpc:lcgcmake [2015/08/24 15:26]
jchilders [LCGCMake]
hpc:lcgcmake [2015/08/24 19:29]
jchilders
Line 16: Line 16:
     * ''soft add +cmake''     * ''soft add +cmake''
     * ''soft add +gcc-4.8.1''     * ''soft add +gcc-4.8.1''
-=== Install Dependencies ===+==== Install Dependencies ====
   * ''mkdir dependencies''   * ''mkdir dependencies''
   * ''cd dependencies''   * ''cd dependencies''
Line 59: Line 59:
 === Before you build === === Before you build ===
 +  * The bits below are summarized in this patch file [[hpc:lcgcmake:cooleyPatchFile|Cooley Patch File]]
   * Edit ''lcgcmake/toolchain.cmake'' line 2 <code cmake> set(LCG_VERSION dev2 CACHE STRING "HepTools version (aka LCG configuration)") </code> to <code cmake> set(LCG_VERSION 78root6 CACHE STRING "HepTools version (aka LCG configuration)") </code>   * Edit ''lcgcmake/toolchain.cmake'' line 2 <code cmake> set(LCG_VERSION dev2 CACHE STRING "HepTools version (aka LCG configuration)") </code> to <code cmake> set(LCG_VERSION 78root6 CACHE STRING "HepTools version (aka LCG configuration)") </code>
   * You have to force cmake to identify your machine as slc6 because some of the tarballs live on a webserver with ''slc6'' in the name, in the case of Cooley, ''slc6'' gets replaced with ''linux'' and the downloads fail since there is no tarball with ''linux'' in the name. Edit ''lcgcmake/cmake/toolchain/heptools-common.cmake'' around line 75 from <code cmake>else()   * You have to force cmake to identify your machine as slc6 because some of the tarballs live on a webserver with ''slc6'' in the name, in the case of Cooley, ''slc6'' gets replaced with ''linux'' and the downloads fail since there is no tarball with ''linux'' in the name. Edit ''lcgcmake/cmake/toolchain/heptools-common.cmake'' around line 75 from <code cmake>else()
Line 119: Line 120:
 -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER}
 -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</code> -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</code>
 +  * Edit ''lcgcmake/externals/CMakeLists.txt'' around line ? in the hepmc3 package and add the lines <code cmake>-DCMAKE_C_COMPILER=${CMAKE_C_COMPILER}
 +-DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</code>.
   * Edit ''lcgcmake/externals/CMakeLists.txt'' around line 842 in the igprof package and comment out the ''-Wno-error=unused-result''.   * Edit ''lcgcmake/externals/CMakeLists.txt'' around line 842 in the igprof package and comment out the ''-Wno-error=unused-result''.
   * Edit ''lcgcmake/externals/CMakeLists.txt'' line 339 in the hepmc3 package from <code cmake>    * Edit ''lcgcmake/externals/CMakeLists.txt'' line 339 in the hepmc3 package from <code cmake>
hpc/lcgcmake.txt ยท Last modified: 2015/08/24 19:29 by jchilders
