User Tools
Site Tools
hpc:othernotes
Differences
Link to this comparison view
Last revision Both sides next revision
hpc:othernotes [2015/01/15 19:28]
jchilders
hpc:othernotes [2015/01/15 19:29]
jchilders
Line 13: Line 13:
 </code> </code>
 +=== Removing a password ===
 In the case of a Robotic Certificate, a password on the key will stop programs which use it so the password must be removed. Just use: In the case of a Robotic Certificate, a password on the key will stop programs which use it so the password must be removed. Just use:
 <code bash> <code bash>
Line 19: Line 20:
 It will ask for the password on the old file, and you can skip entering one for the new file. You may also need to change ''x509'' to ''rsa'' or whichever protocol is being used. It will ask for the password on the old file, and you can skip entering one for the new file. You may also need to change ''x509'' to ''rsa'' or whichever protocol is being used.
 +=== Updating certificates CA directory ===
 I've typically had to update the local copy of our CA certificate folder by grabbing the one at CERN: I've typically had to update the local copy of our CA certificate folder by grabbing the one at CERN:
 ''lxplus.cern.ch:/etc/grid-security/certificates'' ''lxplus.cern.ch:/etc/grid-security/certificates''
 and copying it locally. Otherwise you get errors from ''voms-proxy-init''. and copying it locally. Otherwise you get errors from ''voms-proxy-init''.
 +=== Testing Success ===
 To test the robotic key/cert you can do the following: To test the robotic key/cert you can do the following:
hpc/othernotes.txt ยท Last modified: 2015/01/15 19:31 by jchilders
