hpc:pythia [2014/01/16 15:23] jchilders |
hpc:pythia [2014/01/21 22:24] jchilders [On ''acinode.hep.anl.gov''] |
Line 1: | Line 1: | ||
- | ===== Building Pythia ===== | + | ===== Building Pythia |
- | ==== Part 1: Build HepMC ==== | + | ==== Part 1: Build HepMC Library |
- | - Check out HepMC from SVN: <code bash>svn co svn+ssh:// | + | - Check out HepMC from SVN: <code bash>svn co svn+ssh:// |
- | - Inside the HepMC folder run <code bash> | + | - Inside the HepMC folder run <code bash> |
- | ==== Part 2: Build Pythia ==== | + | ==== Part 2: Build Pythia |
- Check out Pythia from SVN: <code bash>svn co svn+ssh:// | - Check out Pythia from SVN: <code bash>svn co svn+ssh:// | ||
- | - Inside the Pythia folder run <code bash> | + | - Inside the Pythia folder run <code bash> |
+ | ==== Part 3: Build Pythia Executable ==== | ||
+ | - Check out TCLAP from SVN: <code bash>svn co svn+ssh:// | ||
+ | - Check out Pythia user code from SVN: <code bash>svn co svn+ssh:// | ||
+ | - Inside the '' | ||
+ | * There is a '' | ||
+ | ===== Pythia Performance ===== | ||
+ | ==== On '' | ||
+ | This is the Pythia performance on '' | ||
+ | * 'N Showered Events' | ||
+ | * 'CPU Time' are the seconds reported by the ' | ||
+ | If you don't see anything but white-space below this text, hit '' | ||
+ | <html>< | ||
