User Tools
Site Tools
hpc:rabbitmq
Differences
Link to this comparison view
Next revision
Previous revision
hpc:rabbitmq [2014/03/18 13:41]
jchilders
hpc:rabbitmq [2016/06/24 16:28]
jchilders
Line 1: Line 1:
 ==== RabbitMQ Documentation ==== ==== RabbitMQ Documentation ====
-   * <html><a href="http://www.rabbitmq.com/documentation.html" target="_blank">RabbitMQ documentation</a></html>+   * <html><a href="http://www.rabbitmq.com/documentation.html" target="_blank">RabbitMQ</a></html>
    * <html><a href="http://pika.readthedocs.org/en/latest/intro.html" target="_blank">Pika</a></html> (used for RabbitMQ Python interface)    * <html><a href="http://pika.readthedocs.org/en/latest/intro.html" target="_blank">Pika</a></html> (used for RabbitMQ Python interface)
 +==== SSL Certificate Usage ====
 +   * Followed <html><a href="http://www.rabbitmq.com/ssl.html" target="_blank">RabbitMQ documentation</a></html> to produce SSL server/client certificates.
 +   * Added this code to the RabbitMQ Server configuration file:
 +<code python>
 +  {rabbit, [
 +     {ssl_listeners, [5671]},
 +     {ssl_options, [{cacertfile,"/path/to/testca/cacert.pem"},
 +                    {certfile,"/path/to/server/cert.pem"},
 +                    {keyfile,"/path/to/server/key.pem"},
 +                    {verify,verify_peer},
 +                    {fail_if_no_peer_cert,true}]}
 +</code>
 +   * Added this code to the RabbitMQ Client (via Pika) Setup:
 +<code python>
 +#!/usr/bin/env python
 +import pika
 +import sys,ssl
 +# Setup our ssl options
 +ssl_options = {"ca_certs": "/path/to/testca/cacert.pem",
 +               "certfile": "/path/to/client/cert.pem",
 +               "keyfile": "/path/to/client/key.pem",
 +               "cert_reqs": ssl.CERT_REQUIRED,
 +connection = pika.BlockingConnection(pika.ConnectionParameters(host='servername.com',port=5671,ssl=True,ssl_options=ssl_options))
 +channel = connection.channel()
 +channel.queue_declare(queue='hello')
 +channel.basic_publish(exchange='',
 +                      routing_key='hello',
 +                      body='Hello World!')
 +print " [x] Sent 'Hello World!'"
 +connection.close()
 +</code>
 +===== Errors =====
 +Make sure cacerts.pem is up to date.
 +cat all /etc/grid-security/ceriticates/*.pem to cacerts.pem.
hpc/rabbitmq.txt ยท Last modified: 2016/06/24 16:28 by jchilders
