hpc:sherpa
Differences
hpc:sherpa [2016/02/18 21:36] – [Installing OpenLoops] jchilders | hpc:sherpa [2016/03/09 15:52] – [Compilation and Installation at Edison@NERSC] jchilders | ||
Line 45: | Line 45: | ||
=== Compilation === | === Compilation === | ||
- | Unpack Sherpa tarball and enter sherpa main directory. | + | Unpack Sherpa tarball and enter sherpa main directory. |
Then run: | Then run: | ||
<WRAP prewrap> | <WRAP prewrap> | ||
- | mkdir install | + | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ |
- | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ | + | |
make -j 10 | make -j 10 | ||
make install | make install | ||
Line 429: | Line 428: | ||
On Edison@NERSC: | On Edison@NERSC: | ||
- | * <code bash> module unload altd | + | <code bash> |
module unload darshan | module unload darshan | ||
module unload PrgEnv-intel | module unload PrgEnv-intel | ||
Line 439: | Line 438: | ||
module load boost | module load boost | ||
module load gsl | module load gsl | ||
- | ./scons | + | ./ |
- | </ | + | ./scons auto=all/ -j 15</ |
- | - Setup: | + | Setup: |
* On Tukey only <code bash> | * On Tukey only <code bash> | ||
* On SLC6 machine: scons needs gcc-4.6+ so use ATLAS compiler: | * On SLC6 machine: scons needs gcc-4.6+ so use ATLAS compiler: |
hpc/sherpa.txt · Last modified: 2017/01/17 15:21 by jchilders
