hpc:sherpa
Differences
hpc:sherpa [2016/02/18 21:36] – [Installing OpenLoops] jchilders | hpc:sherpa [2016/03/10 15:45] – [Compiling on Mira@ALCF] jchilders | ||
Line 14: | Line 14: | ||
* The code generation step of Sherpa produces a '' | * The code generation step of Sherpa produces a '' | ||
* 200900 = W+jets, 200901 = Z+jets, 200903 = Drell-Yan, 200910 = Multi-jets | * 200900 = W+jets, 200901 = Z+jets, 200903 = Drell-Yan, 200910 = Multi-jets | ||
* During a run Sherpa dlopen() calls the following libraries: | * During a run Sherpa dlopen() calls the following libraries: | ||
Line 23: | Line 22: | ||
* openloops/ | * openloops/ | ||
* libSherpaHepMcOutput.so | * libSherpaHepMcOutput.so | ||
+ | * Runtime Errors and Possible Meanings: | ||
===== Compilation and Installation at Edison@NERSC ===== | ===== Compilation and Installation at Edison@NERSC ===== | ||
Line 45: | Line 47: | ||
=== Compilation === | === Compilation === | ||
- | Unpack Sherpa tarball and enter sherpa main directory. | + | Unpack Sherpa tarball and enter sherpa main directory. |
Then run: | Then run: | ||
<WRAP prewrap> | <WRAP prewrap> | ||
- | mkdir install | + | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ |
- | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ | + | |
make -j 10 | make -j 10 | ||
make install | make install | ||
Line 167: | Line 168: | ||
export PATH=$PATH: | export PATH=$PATH: | ||
- | ===== Compiling on Mira@ALCF ===== | + | ===== Compiling on Mira/Cetus@ALCF ===== |
* <WRAP prewrap> <code bash> | * <WRAP prewrap> <code bash> | ||
- | svn export svn+ssh:// | + | soft add +bgqtoolchain-gcc484 |
- | cd sherpa-03-00-00 | + | soft add +python-2.7 |
- | ./configure --enable-mpi --with-pic --enable-gzip=/ | + | svn export svn+ssh:// |
+ | cd 01-00-00 | ||
+ | ./configure --enable-mpi --with-pic --enable-gzip=/ | ||
+ | # build and install sqlite3 | ||
+ | # rerun configure with: --with-sqlite3=</ | ||
make -j 20 install</ | make -j 20 install</ | ||
* Hopefully, now everything is working. | * Hopefully, now everything is working. | ||
Line 429: | Line 434: | ||
On Edison@NERSC: | On Edison@NERSC: | ||
- | * <code bash> module unload altd | + | <code bash> |
module unload darshan | module unload darshan | ||
module unload PrgEnv-intel | module unload PrgEnv-intel | ||
Line 439: | Line 444: | ||
module load boost | module load boost | ||
module load gsl | module load gsl | ||
- | ./scons | + | ./ |
- | </ | + | ./scons auto=all/ -j 15</ |
- | - Setup: | + | Setup: |
* On Tukey only <code bash> | * On Tukey only <code bash> | ||
* On SLC6 machine: scons needs gcc-4.6+ so use ATLAS compiler: | * On SLC6 machine: scons needs gcc-4.6+ so use ATLAS compiler: |
hpc/sherpa.txt · Last modified: 2017/01/17 15:21 by jchilders
