hpc:sherpa
Differences
hpc:sherpa [2016/03/09 14:32] – [Installing OpenLoops] jchilders | hpc:sherpa [2016/03/10 15:00] – [Some Notes] jchilders | ||
Line 14: | Line 14: | ||
* The code generation step of Sherpa produces a '' | * The code generation step of Sherpa produces a '' | ||
* 200900 = W+jets, 200901 = Z+jets, 200903 = Drell-Yan, 200910 = Multi-jets | * 200900 = W+jets, 200901 = Z+jets, 200903 = Drell-Yan, 200910 = Multi-jets | ||
* During a run Sherpa dlopen() calls the following libraries: | * During a run Sherpa dlopen() calls the following libraries: | ||
Line 23: | Line 22: | ||
* openloops/ | * openloops/ | ||
* libSherpaHepMcOutput.so | * libSherpaHepMcOutput.so | ||
+ | * Runtime Errors and Possible Meanings: | ||
===== Compilation and Installation at Edison@NERSC ===== | ===== Compilation and Installation at Edison@NERSC ===== | ||
Line 45: | Line 47: | ||
=== Compilation === | === Compilation === | ||
- | Unpack Sherpa tarball and enter sherpa main directory. | + | Unpack Sherpa tarball and enter sherpa main directory. |
Then run: | Then run: | ||
<WRAP prewrap> | <WRAP prewrap> | ||
- | mkdir install | + | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ |
- | ./configure --enable-mpi --enable-gzip --with-sqlite3=/ | + | |
make -j 10 | make -j 10 | ||
make install | make install | ||
Line 429: | Line 430: | ||
On Edison@NERSC: | On Edison@NERSC: | ||
- | * <code bash> | + | <code bash> |
module unload darshan | module unload darshan | ||
module unload PrgEnv-intel | module unload PrgEnv-intel | ||
Line 439: | Line 440: | ||
module load boost | module load boost | ||
module load gsl | module load gsl | ||
- | ./scons | + | ./scons -j 10 |
- | </ | + | ./scons auto=all/ -j 15</ |
- | * <code bash>./scons -j 10</ | + | |
- | * <code bash>./scons auto=all/ -j 15</ | + | |
Setup: | Setup: |
hpc/sherpa.txt · Last modified: 2017/01/17 15:21 by jchilders
