hpc:sherpa [2016/03/10 15:45] jchilders [Compiling on Mira@ALCF] |
hpc:sherpa [2016/03/10 19:52] jchilders [Installing OpenLoops] |
Line 446: | Line 446: | ||
./scons -j 10 | ./scons -j 10 | ||
./scons auto=all/ -j 15</ | ./scons auto=all/ -j 15</ | ||
+ | On Mira/ | ||
+ | * <code bash> | ||
+ | soft add +mpiwrapper-gcc | ||
+ | soft add +python2.7.9</ | ||
+ | * Checkout from ATLAS: <code bash> svn co --username atlas https:// | ||
+ | * <code bash>cd atlas_ol</ | ||
+ | * Make these changes:< | ||
+ | --- pyol/ | ||
+ | +++ pyol/ | ||
+ | @@ -8,8 +8,8 @@ | ||
+ | -supported_compilers = gfortran ifort | ||
+ | -fortran_compiler = gfortran | ||
+ | +supported_compilers = gfortran ifort mpif90 | ||
+ | +fortran_compiler = mpif90 | ||
+ | cc = gcc | ||
+ | cxx = g++ | ||
+ | Index: lib_src/ | ||
+ | --- lib_src/ | ||
+ | +++ lib_src/ | ||
+ | @@ -18,6 +18,7 @@ | ||
+ | + use ISO_FORTRAN_ENV | ||
+ | @@ -35,7 +36,8 @@ | ||
+ | ! #ifdef USE_qp | ||
+ | - integer, parameter :: qp = selected_real_kind(33) | ||
+ | +! integer, parameter :: qp = selected_real_kind(33) | ||
+ | + integer, parameter :: qp = REAL128 | ||
+ | ! #endif | ||
+ | @@ -1108,7 +1108,7 @@ | ||
+ | if (index(trim(infofilename)," | ||
+ | cycle | ||
+ | else | ||
+ | - infofilename = trim(install_path) // "/ | ||
+ | + infofilename = trim(install_path) // "/ | ||
+ | end if | ||
+ | * To build: <code bash> | ||
+ | * To download and build all processes: <code bash> | ||
Setup: | Setup: |
