hpc:sherpa [2016/04/15 16:09] jchilders [Compiling on Mira/Cetus@ALCF] |
hpc:sherpa [2017/01/17 15:21] jchilders |
Line 25: | Line 25: | ||
* Runtime Errors and Possible Meanings: | * Runtime Errors and Possible Meanings: | ||
===== Compilation and Installation at Edison@NERSC ===== | ===== Compilation and Installation at Edison@NERSC ===== | ||
Line 181: | Line 182: | ||
* Hopefully, now everything is working. | * Hopefully, now everything is working. | ||
* You may need to copy the HepMC and sqlite3 libraries to the installed sherpa library directory. | * You may need to copy the HepMC and sqlite3 libraries to the installed sherpa library directory. | ||
- | + | * I have run into these problems in the past: | |
+ | * <WRAP prewrap> <code make> / | ||
===== Compiling on Vesta@ALCF ===== | ===== Compiling on Vesta@ALCF ===== |
