Next revision | Previous revision | ||
hpc:svnrepo [2014/01/09 16:53] jchilders created |
hpc:svnrepo [2014/01/09 16:59] jchilders old revision restored (2014/01/09 10:55) |
Line 1: | Line 1: | ||
===== ATLAS HEP HPC SVN Repository ===== | ===== ATLAS HEP HPC SVN Repository ===== | ||
==== Repository Coordinates ==== | ==== Repository Coordinates ==== | ||
The repository address is: \\ | The repository address is: \\ | ||
==== Checkout Repository ==== | ==== Checkout Repository ==== | ||
Run the following on your command line: | Run the following on your command line: | ||
- | svn co svn+ssh://< | + | svn co svn+ssh://< |
This will check out everything in the repository to the directory '' | This will check out everything in the repository to the directory '' | ||
