itk:calibration_with_hsio
Differences
itk:calibration_with_hsio [2017/02/04 00:19] – dfrizzell | itk:calibration_with_hsio [2017/02/06 17:13] – dfrizzell | ||
Line 1: | Line 1: | ||
====== Calibration with HSIO ====== | ====== Calibration with HSIO ====== | ||
- | This will outline the calibration of a FEI4B pixel readout using the HSIO-2 RCE. | + | This will outline the calibration of a FEI4B pixel readout using the HSIO-2 RCE. |
+ | For setup and installation help see the installation section of: | ||
+ | https:// | ||
+ | ====== Setting up Calibration GUI ====== | ||
+ | **To begin calibration disable wifi and enable ethernet connection with the HSIO-2 that is connected to your computer. Inside of a terminal, ssh into the HSIO-2 and setup the calibration server by executing this code:** | ||
+ | $>arp -a #reveals IP addresses of devices connected to computer | ||
+ | $>ssh [email protected]._ #Use the IP address for rce0 obtained from arp. Password = root | ||
+ | $>source setup.sh #setup environment inside of HSIO-2 | ||
+ | Make sure the steps here https:// | ||
+ | **Next setup the calibration GUI in another terminal WITH superuser privileges: | ||
+ | $>cd ~/daq/rce #move to rce directory | ||
+ | $>source ./ | ||
+ | If any errors occur make sure the steps have been done here: https:// | ||
+ | ===== Single Scan to Verify Everything is Working (Optional) ===== | ||
+ | **On the GUI select Save As and select a location for the log file to be saved. I simply make a directory ($>mkdir ~/ | ||
+ | The default configuration file is not setup for the chip geometry currently at ANL-ASC (02-06-2016). To fix this open the .cfg file and edit the address parameter from 7 to 8. | ||
+ | To communicate with the rce you may need to add a line into the /etc/hosts file. Add the line: " | ||
+ | //Under construction// |
itk/calibration_with_hsio.txt · Last modified: 2017/02/06 21:00 by dfrizzell
