itk:calibration_with_hsio
Differences
itk:calibration_with_hsio [2017/02/06 17:10] – dfrizzell | itk:calibration_with_hsio [2017/02/06 19:20] – dfrizzell | ||
Line 27: | Line 27: | ||
===== Single Scan to Verify Everything is Working (Optional) ===== | ===== Single Scan to Verify Everything is Working (Optional) ===== | ||
- | **On the GUI select Save As and select a location for the log file to be saved. I simply make a directory ($>mkdir ~/ | + | **On the GUI select Save As and select a location for the log file to be saved. I simply make a directory ($>mkdir ~/ |
+ | The default configuration file, (94-22-04_25__cern__6999.cfg) is not setup for the chip geometry currently at ANL-ASC (02-06-2016). To fix this open the file and edit the ' | ||
+ | To communicate with the rce you may need to add a line into the /etc/hosts file. Add the line: " | ||
//Under construction// | //Under construction// |
itk/calibration_with_hsio.txt · Last modified: 2017/02/06 21:00 by dfrizzell
