Both sides previous revision Previous revision | Last revision Both sides next revision | ||
itk:calibration_with_hsio [2017/02/06 20:29] dfrizzell |
itk:calibration_with_hsio [2017/02/06 20:30] dfrizzell |
Line 74: | Line 74: | ||
The logic behind the primlist file is fairly obvious and can be manipulated and altered as the user desires different parameters, orderings, or scans. | The logic behind the primlist file is fairly obvious and can be manipulated and altered as the user desires different parameters, orderings, or scans. | ||
- | **It is most instructive to run a diagnostic scan such as the THRESHOLD_SCAN on the default .cfg file, then again on the last .cfg file after the primlist has run (for example in the ~/ | + | **It is most instructive to run a diagnostic scan such as the THRESHOLD_SCAN on the default .cfg file, then again on the last .cfg file after the primlist has run (for example in the ~/ |
//Still Under Construction// | //Still Under Construction// |
