itk:calibration_with_hsio [2017/02/06 20:29] dfrizzell |
itk:calibration_with_hsio [2017/02/06 21:00] dfrizzell This is essentially the initial commit. Everything up to this point has been preperation. |
Line 6: | Line 6: | ||
The bold font indicates action items and regular text gives supplemental information. | The bold font indicates action items and regular text gives supplemental information. | ||
====== Setting up Calibration GUI ====== | ====== Setting up Calibration GUI ====== | ||
Line 20: | Line 21: | ||
$>cd ~/daq/rce #move to rce directory | $>cd ~/daq/rce #move to rce directory | ||
- | $>source ./ | + | $>source ./ |
Line 29: | Line 30: | ||
**On the GUI select Save As and select a location for the log file to be saved. I simply make a directory ($>mkdir ~/ | **On the GUI select Save As and select a location for the log file to be saved. I simply make a directory ($>mkdir ~/ | ||
The default configuration file, (94-22-04_25__cern__6999.cfg) is not setup for the chip geometry currently at ANL-ASC (02-06-2016). To fix this open the file and edit the ' | The default configuration file, (94-22-04_25__cern__6999.cfg) is not setup for the chip geometry currently at ANL-ASC (02-06-2016). To fix this open the file and edit the ' | ||
Line 35: | Line 39: | ||
- | **Once the test run is complete you will be able to go into the ' | + | **Once the test run is complete you will be able to go into the ' |
If for example, I ran a FDAC_TUNE there would be a folder in the calibData directory ' | If for example, I ran a FDAC_TUNE there would be a folder in the calibData directory ' | ||
Line 74: | Line 80: | ||
The logic behind the primlist file is fairly obvious and can be manipulated and altered as the user desires different parameters, orderings, or scans. | The logic behind the primlist file is fairly obvious and can be manipulated and altered as the user desires different parameters, orderings, or scans. | ||
- | **It is most instructive to run a diagnostic scan such as the THRESHOLD_SCAN on the default .cfg file, then again on the last .cfg file after the primlist has run (for example in the ~/ | + | **It is most instructive to run a diagnostic scan such as the THRESHOLD_SCAN on the default .cfg file, then again on the last .cfg file after the primlist has run (for example in the ~/ |
+ | ===== Questions, Comments, or Corrections ===== | ||
+ | [email protected] | ||
- | //Still Under Construction// |
