itk:fei4b [2016/03/03 21:45] rwang [Data analysis] |
itk:fei4b [2016/09/01 08:18] asc |
Line 1: | Line 1: | ||
+ | This wiki describes UsbPix teststand. | ||
+ | Alternatively, | ||
===== Setup documentation ===== | ===== Setup documentation ===== | ||
Line 25: | Line 27: | ||
+ | See some notes in [[https:// | ||
===== CentOS7 instruction ===== | ===== CentOS7 instruction ===== | ||
Line 76: | Line 79: | ||
- Download Java Runtime Environment 8 (32 bits, to be consistent with Eclipse) from http:// | - Download Java Runtime Environment 8 (32 bits, to be consistent with Eclipse) from http:// | ||
- Download Eclipse with PyDev (32-bit Eclipse IDE for C/C++ Developers) from http:// | - Download Eclipse with PyDev (32-bit Eclipse IDE for C/C++ Developers) from http:// | ||
- | - Download git | + | - Download git https:// |
- Download vivoda Lab Edition from http:// | - Download vivoda Lab Edition from http:// | ||
- Download unzip from http:// | - Download unzip from http:// | ||
Line 82: | Line 85: | ||
====Install usb3.0==== | ====Install usb3.0==== | ||
Follow the steps in https:// | Follow the steps in https:// | ||
- | - make sure no driver installed for the cypress usb3.0 | + | - make sure no driver installed for the cypress usb3.0 |
- in Device manager looking in the "other device" | - in Device manager looking in the "other device" | ||
- | - install the cypress kit from http:// | + | - install the cypress kit from [[http:// |
+ | - If you use Windows 10, use these dedicated drives [[http:// | ||
- right click on the " | - right click on the " | ||
- Ordered List Itemopen the control center, the " | - Ordered List Itemopen the control center, the " | ||
- | - Ordered List Itemupload the .img file " | + | - Ordered List Itemupload the .img file " |
- | - **Not Need** | + | - use Zadig to reinstall FX3 device |
- | - reboot PC | + | - the USB devices " |
- | - select " | + | - select " |
- install driver WinUSB(v6.1.7600.16385) | - install driver WinUSB(v6.1.7600.16385) | ||
- download libusb 1.0.20 from http:// | - download libusb 1.0.20 from http:// | ||
Line 99: | Line 103: | ||
==Install basil mio3== | ==Install basil mio3== | ||
- | change " | + | change " |
+ | You will need the branch " | ||
+ | If you will use wrong basil, when running " | ||
Download pySiLibUSB from https:// | Download pySiLibUSB from https:// | ||
Line 142: | Line 149: | ||
====Data structure==== | ====Data structure==== | ||
- | ==Raw data== | + | ===Raw data=== |
The raw data contains all FE words + FPGA trigger words + FPGA TDC words in an one dimensional array. | The raw data contains all FE words + FPGA trigger words + FPGA TDC words in an one dimensional array. | ||
Every word is a 32-bit unsigned int. The format is: 82444303 = **0** 000 __0100__ 1110 1010 0000 0000 0000 1111 | Every word is a 32-bit unsigned int. The format is: 82444303 = **0** 000 __0100__ 1110 1010 0000 0000 0000 1111 | ||
Line 183: | Line 190: | ||
* service_record: | * service_record: | ||
* event_status: | * event_status: | ||
+ | ===Clustered Data=== | ||
+ | Clustered data is usually stored as additional nodes in the analyzed data file or in a new file. The nodes are cluster hits, cluster or histograms. | ||
+ | ==Cluster hits== | ||
+ | The table ClusterHits is a copy of the Hits table (see above) but with four additional columns: | ||
+ | * cluster_id: The cluster ID of the hit [0:number of cluster in the event] | ||
+ | * is_seed: Is one if the hit is the seed hit, otherwise 0. | ||
+ | * cluster_size: | ||
+ | * n_cluster: The number of cluster of the event the hit belongs to. | ||
+ | ==Cluster== | ||
+ | The table Cluster stores the infos for each cluster. | ||
+ | The columns are: | ||
+ | * event_number: | ||
+ | * id: The cluster ID of the cluster [0:number of cluster in the event]. | ||
+ | * size: The number of hits that belong to the cluster. | ||
+ | * tot: The tot sum of all hits. | ||
+ | * charge: The charge sum of all hits (not used yet). | ||
+ | * seed_column: | ||
+ | * seed_row: The row of the seed pixel. | ||
+ | * event_status: | ||
====Simple data convertion==== | ====Simple data convertion==== | ||
pyBAR provide few scripts under pybar/scan for raw data analysis. | pyBAR provide few scripts under pybar/scan for raw data analysis. | ||
Line 207: | Line 243: | ||
======Data analysis====== | ======Data analysis====== | ||
