itk:fei4b [2016/03/03 21:50] rwang [Data structure] |
itk:fei4b [2016/09/01 08:18] asc |
Line 1: | Line 1: | ||
+ | This wiki describes UsbPix teststand. | ||
+ | Alternatively, | ||
===== Setup documentation ===== | ===== Setup documentation ===== | ||
Line 25: | Line 27: | ||
+ | See some notes in [[https:// | ||
===== CentOS7 instruction ===== | ===== CentOS7 instruction ===== | ||
Line 76: | Line 79: | ||
- Download Java Runtime Environment 8 (32 bits, to be consistent with Eclipse) from http:// | - Download Java Runtime Environment 8 (32 bits, to be consistent with Eclipse) from http:// | ||
- Download Eclipse with PyDev (32-bit Eclipse IDE for C/C++ Developers) from http:// | - Download Eclipse with PyDev (32-bit Eclipse IDE for C/C++ Developers) from http:// | ||
- | - Download git | + | - Download git https:// |
- Download vivoda Lab Edition from http:// | - Download vivoda Lab Edition from http:// | ||
- Download unzip from http:// | - Download unzip from http:// | ||
Line 82: | Line 85: | ||
====Install usb3.0==== | ====Install usb3.0==== | ||
Follow the steps in https:// | Follow the steps in https:// | ||
- | - make sure no driver installed for the cypress usb3.0 | + | - make sure no driver installed for the cypress usb3.0 |
- in Device manager looking in the "other device" | - in Device manager looking in the "other device" | ||
- | - install the cypress kit from http:// | + | - install the cypress kit from [[http:// |
+ | - If you use Windows 10, use these dedicated drives [[http:// | ||
- right click on the " | - right click on the " | ||
- Ordered List Itemopen the control center, the " | - Ordered List Itemopen the control center, the " | ||
- | - Ordered List Itemupload the .img file " | + | - Ordered List Itemupload the .img file " |
- | - **Not Need** | + | - use Zadig to reinstall FX3 device |
- | - reboot PC | + | - the USB devices " |
- | - select " | + | - select " |
- install driver WinUSB(v6.1.7600.16385) | - install driver WinUSB(v6.1.7600.16385) | ||
- download libusb 1.0.20 from http:// | - download libusb 1.0.20 from http:// | ||
Line 99: | Line 103: | ||
==Install basil mio3== | ==Install basil mio3== | ||
- | change " | + | change " |
+ | You will need the branch " | ||
+ | If you will use wrong basil, when running " | ||
Download pySiLibUSB from https:// | Download pySiLibUSB from https:// | ||
Line 236: | Line 243: | ||
======Data analysis====== | ======Data analysis====== | ||
