itk:glossary [2016/05/26 15:38] mazhang |
itk:glossary [2016/05/26 16:41] mazhang |
Line 2: | Line 2: | ||
* **COB** - A DAQ board like the HSIO-II, but suited for more large-scale stuff. | * **COB** - A DAQ board like the HSIO-II, but suited for more large-scale stuff. | ||
- | * **DHCP** - [[https:// | + | * **DHCP** - [[https:// |
* **DPM** - | * **DPM** - | ||
* **DTM** - | * **DTM** - | ||
* **HSIO-II** - High Speed Input Output II. This is a board for performing testing on pixel detectors. It looks like [[https:// | * **HSIO-II** - High Speed Input Output II. This is a board for performing testing on pixel detectors. It looks like [[https:// | ||
+ | * **MAC** - Media Access Control. If an IP address is like a device' | ||
* **NFS** - [[https:// | * **NFS** - [[https:// | ||
- | * **NTP** - [[https:// | + | * **NTP** - [[https:// |
* **RCE** - A [[https:// | * **RCE** - A [[https:// | ||
* **SDK** - Software Development Kit. Software packages and stuff you need to write, compile, and write code. | * **SDK** - Software Development Kit. Software packages and stuff you need to write, compile, and write code. |
